goldentoxicspen's avatar
Jul 12, 2020
Enable "Bridge mode" on Orbi RBR50
I currently have a daisy chain of orbi's connected to internet. I want to add my nighthawk r7000 as an extension so I have access to some more ethernet ports in the house without a long wire. So I set up the R7000 in repeating mode and it is all set up. But as seen in this video (https://www.youtube.com/watch?v=6YhVzhESUy4) I need to enable on the orbi whatever the equivalent of "WDS Bridging" would be for the oribi. How do I do that or is ther another way to add the r7000 to the network?
  • By chance I have a Nighthawk R7000 connect to my Orbi for the same purpose: to provide a bunch of ethernet ports in my garage where it is impractical to run an ethernet cable from my Orbi.
    Nothing is configured on the Orbi. Nothing.
    On the R7000, I went to the Advanced Tab, Advanced Setup, Router/AP/Bridge, and set it to Bridge Mode.  I also went into the Advanced Wireless settings and disabled the 2.4G radio.  The garage R7000 does not support any WiFi clients.  I believe how to do this is described in the R7000 User Manual.
    Works Great.
  • CrimpOn's avatar
    CrimpOn
    Works Great.
