- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Errors accessing or linking to many web pages RBK23 AC2200
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Errors accessing or linking to many web pages RBK23 AC2200
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If there is a router in between the Orbi and modem, the could be the cause of your problems.
The middle router needs to be removed and connect the RBR directly to the ISP modem or configured the Orbi for AP mode:
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the IP address the Orbi router is getting from the Modem/Router?
Try accessing the RBR at 192.168.1.1. If you can't access the RBR, then the RBR is getting a different IP address or maybe in conflict with the up stream router.
You need to try one of the 2 suggestions...
If the Orbi IS connected directly to the ISP Modem, then you should be able to access the RBR at orbilogin.com or 192.168.1.1.
You might power cycle OFF the modem, factory reset the RBR, Power ON the ISP modem. With a wired PC connected to the back of the RBR, use a web browser to access orbilogin.com or 192.168.1.1. Ensure your PCs networking is set for auto obtain IP addressing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good to hear. Glad that worked for you.
Might exit the site. Clear browser cache then log back in and set the solution.
ENjoy.
