Orbi WiFi 7 RBE973
Reply
Ethernet Backhaul to one satellites
gaqihowu
Follower
I would like to connect the ethernet backhaul from my RBR50 to my RBS50s, but due to wiring accessibility, I can only reasonably get one of my two RBS50s connected via ehternet. Would someone be able to advise if it would cause any issues to operate in this configuration? (Router + ethernet backhaul to one satellite, and wireless backhaul to the second satellite). Thanks.
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 1 of 4
Guru
Re: Ethernet Backhaul to one satellites
Should work fine. I've ran that setup without issues before. I ran my rbs50's wired and rbs40v and rbs50y with them wireless and everything still worked well.
Message 2 of 4
tomschmidt
Virtuoso
Yes, that will work fine, as that is how my setup is running. I have star configuration with one RBS50 satellite wired to the RBR50 for its backhaul, and the second RBS50 using the 5GHz wireless backhaul.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 793 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
