- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ethernet backhaul causes crash if anything else is on the switch
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've heard of others having issues with ethernet backhaul. I suspect mine is similar. Short story: if any device other than the connection for ethernet backhaul is connected to the satellite or router, the whole system quickly crashes. I presume this is because the system can't figure out which device is for the backhaul and what's a regular old device on the network.
Any suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ethernet backhaul causes crash if anything else is on the switch
Do you have a switch connected to the orbi? or another type of router?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried it with a switch between just for **bleep**s. Same result.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I want to get you in contact with support send me a PM with your name email and phone number and I will get you with support.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
I also had issues when I wired the satellites to the Orbi Router. My internet connection was dropping for 10-60 secs every few minutes. After an hour with tech support, we unplugged and just connected the satellites wirelessly and all seems good. Of course, now the satellites are notwhere I need them to be.... hopefully the issues will get resolved and I can use the wired backhaul again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Last night my Orbi developed this problem. It had functioned flawlessly for almost 2 months. I have one satellite connected by ethernet backhaul, and one connected wirelessly. This morning had not internet access. When I tried to ping the router it would not reply. I unplugged all of the ethernet connections and it immediately began to reply. One by one I went through unplugging my wired devices to figure out which device was causing the main Orbi to crash, and upon unplugging the ethernet backhaul to the Orbi satellite, it began responding to pings. Strange. It had worked fine in that configuration. Anyway, everything is working again, as long as the ethernet isn't plugged in to the Orbi satellite.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try the following to get the Ethernet Backhaul up and running.
Disconnect the Ethernet backhaul cable (I know in your case it is already disconnected).
From within the Router GUI remove the Satellite
Add the satellite as a new satellite wirelessly and allow it to connect and show the Blue light
Reconnect the Ethernet cable to establish the wired backhaul.
This has worked for me following issues after power cuts.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also try disabling Daisy Chain...
- Mark as New
- Bookmark
- Subscribe
- Permalink
yep ditto here on 2.14.16 = come on netgear this can't be hard. You shouldn't have to jump up and down on one foot while holding A to B while pressing C to get this work - it should just work plugged in.
EDIT : I think where netgear is struggling is that this was never an intended feature at design. I notice how anything connected to the satellite is not immediately detected on a network when powering up the satellite like a switch typically would be. I wonder if the hardware is even there for stable ethernet backhual.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How do I remove the satellite when I’m on the GUI screen.
If I click on it it just allows me to change name no remoce button
- Mark as New
- Bookmark
- Subscribe
- Permalink
Power it off and in the GUI it will state 'Disconnected' and give you the option to 'Remove.' Do this and then add it again wirelessly if you can and then via Ethernet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let u know how it goes. You should be able to get back haul going. Just start with the satelite, switch, router and wired PC first. Set up wireless first then wait for BLUE led, then connect LAN cable to the satellite and wait for the BLUE led to appear on the satellite. Set a IP address reservation, save and apply. Then connect the rest of the LAN network devices.
You can also try the beta FW as well:
Ethernet back haul does work!!!
