- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ethernet ports not working when internet is down
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ethernet ports not working when internet is down
Can you access the RBRs web page with a wired PC when this happens at 192.168.1.1?
Built in router here by chance? If so,
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
As an experiment, I unplugged the CAT6 cable from my cable modem to the WAN port of my Orbi RBR50, thus disabling connectivity to the internet. My local network continued to work, both wired and WiFi systems. I could still access my NAS storage, IP cameras, TiVo (local recordings and over-the-air TV broadcasts) and other local devices. I do not have a FireTV recast so perhaps it depends on the internet. I do have several FireTV sticks, which of course did not work since they could not access the Internet for streaming services.
- Mark as New
- Bookmark
- Subscribe
- Permalink
FYI, when you bridge or use Transparent bridging on those modems. the modems web page becomes inaccessible. Thats normal for those modems. If you disabled Transpartent briding, then you are in a double NAT condition.
@clrd4approach wrote:
Yes I have it set up on transparent bridging, I had to take the gateway with built in modem and turn off transparent bridging and unplug the the orbi system and just use the gateway with built in modem. I do not have a double NAT. The gateway is a zyxel gateway C3000. I have changed the orbi login to 192.168.0.2 so that if I need to get into the gateway I can.
- Mark as New
- Bookmark
- Subscribe
- Permalink
