Orbi WiFi 7 RBE973
Reply
Explicit MAC Filtering
stevefxp
Apprentice
Hello all,
Is there a way to explicitly exclude a MAC from connecting to my Orbi Wifi? I do not see a way to enter a MAC, so that it would be excluded.
Thanks,
Steve
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 5
Accepted Solutions
CrimpOn
Guru
Re: Explicit MAC Filtering
I think this is the intended purpose of Access Control.  Under the "Advanced" tab, select Security, then Access Control.  At the bottom of the screen is where devices which may NOT connect are entered by MAC address.
(Caveat) My understanding is that Access Control was reported not to work correctly in previous firmware versions.  I have never tried it (before today).  I am not charging an old smartphone, have entered the MAC address into the table, and will "see what happens" once it gets charged.
Message 3 of 5
All Replies
Guru
Check under parental controls for blocking?
Message 2 of 5
CrimpOn
Guru
Message 3 of 5
CrimpOn
Guru
I think the answer is "yes".  My old smartphone "connected" to my Orbi, but also said, "no internet."  Nada.  I even tried connecting through an AP in the garage which has a different SSID.  No Joy.
I have no idea if Access Control "works right" in all areas.  It appears to be able to block specific MAC addresses.  (I'm going to turn it back off now.)
Message 4 of 5
stevefxp
Apprentice
I did not see the two sections at the bottom. Thanks for that!
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2265 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
