Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Extending ORBI WIFI using Apple Time Captule
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-04-29
12:15 AM
2020-04-29
12:15 AM
Hi, An ORBI is setup in my house and I have an Apple Time Capsule which I want to use to extend the ORBI signal in my house. Currently the ORBI LAN to connected to the Applie Time Capsule WAN port Need some advice please: When starting up the Time Capsule, do I create a new network or add to existing network? Will this extend the ORBI WIFI through the Time Capsule or will the Time Capsule create another WIFI network which I need to connect to? My objective is to set it up so that it works the same as the ORBI satellite, but at the moment it creates another Apple Time Capsule WIFI network whereas my expectation was to just extend the current ORBI WIFI. Rgrds
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-04-29
06:31 AM
2020-04-29
06:31 AM
Re: Extending ORBI WIFI using Apple Time Captule
You can try Extend to see if it connects to the Orbi WiFi. I may not.
Please contact Apple support and review installation documentation on how to setup there devices.
Which Orbi system do you have? Orbi should be enough to cover and provide wifi signals.
Message 2 of 2
Announcements
