Reply
Extending a 3 Unit Orbi System
msvirick
I have a 3 unit Orbi system, with a 2nd router unused in a closet and a room with a dead spot in a somwhat large house.
Do I buy another extender or can I use my spare router some how
Will a Netgeat N router extend the Wifi to this dead spot (actually a poor connection) @ 30$ solution
Message 1 of 5
Guru
Re: Extending a 3 Unit Orbi System
No. You'll need get an RBS.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.223/SRK30 V3.2.33.106)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, RBK50, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 2 of 5
msvirick
Romm size 12 c 15
Settlite about 55 ft away
Message 3 of 5
msvirick
Romm size 15 c 25
Away from router 75 ft
Away settilite from router 60 ft
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 4 of 5
Guru
Kind of on the upper limits of distance.
May need a another RBS.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 443 views
  • 0 kudos
  • 2 in conversation
Announcements
