Orbi WiFi 7 RBE973
Reply
Extending to garden office
py3083
Follower
Hello everyone - wonder if someone can help me out please?
I've just had an office put in the bottom of my garden and need reliable internet (obvs!)
Currently I have an RBR20 router at the front of the house, with 1 satellite near the back door, and another satellite upstairs.
I'm thinking of running an ethernet cable from the satellite at the back door, down the garden and in to the office.  I would then get another satellite to attach to the other end of that cable and therefore giving me my WIFI in the office too.  (I think it's too far in distance to just put another satellite in the office with no ethernet cable).  Maybe also worth noting that there is no possibility of putting a wired connection from the router to the satellite at the back door.
Does anyone know if this set up would work please?
Very grateful for any help.
Thanks
Phil.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 6
CrimpOn
Guru
Re: Extending to garden office
"It depends".  The maximum ethernet distance is 90 meters (approximately 300ft.).  If the garden shed is within this distance (in cable feet, not line of sight), then this is indeed the best solution - by far.
Orbi allows a combination of backhaul links (WiFi and ethernet).  As you have surmised, the optimal solution is to bypass that back door satellite and go directly to the router. #2 would be ethernet for both backhaul links.  But WiFi plus ethernet will work.
You might consider placing the ethernet cable in PVC conduit in case you need to replace it some time in the future. And, the cable termination on both ends is critical.
Message 2 of 6
Guru
Message 3 of 6
Satchell
I have the same garden office situation. I have nighthawk mesh 6 in the house and a cat 6 cable installed to the garden office. Do i just get another mesh 6 satellite and plug it in at the garden office?
Message 4 of 6
CrimpOn
Guru
That specific question will get a more informed response if posted in the Netgear community forum for the Nighthawk mesh 6 products.
Maybe post here: https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
The User Manual may have instructions on how satellites can connect on the Nighthawk mesh.
Message 5 of 6
CrimpOn
Guru
It seems the answer is "Yes".
From the Nighthawk mesh 6 product data sheet,the middle column of page 6: (also attached):
https://www.netgear.com/images/datasheet/networking/nighthawkmesh/mk63S.pdf
The mesh 6 router has only one ethernet port on the LAN side, so a switch will be required if more than one ethernet device (including satellites) needs a connection.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 759 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
