- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Extension to guest house
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the Orbi Tri-band Whole Home Mesh WiFi System, with Wall Plugs (RBK33) system,
I have extended it to the guest house 400 feet away with two satellites and it works. The problem is that the signal disappears randomly and I need to reboot the router each time to reconnect. Is there away to make sure the connection is permanent. Do I need to buy another router for the guest house and use the AB button or would a powerful extender do the trick?
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Extension to guest house
I'm surprised it even works. 400ft is a long way for a standard wireless setup. A point to point system wouldn't have issues.
that's probably why you're having issues.
You could try something like netgear's airbridge to connect the 2 buildings and then connect a satellite in the other building.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you. So you think that would be better than an additional router on the AP mode.
I looked up the Airbridge and it seems to be perfect. Do I need to buy two or just one and that will connect to the satellites in guest house.
Thank you.
@plemans wrote:I'm surprised it even works. 400ft is a long way for a standard wireless setup. A point to point system wouldn't have issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I apologize if I was not clear. Currently I have two satellites in the guest house.
Ty.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Apple21 wrote:Thank you. So you think that would be better than an additional router on the AP mode.
Thank you.
In point to point mode it takes 2. one at each end. You'd still need the 2 satellites in the guest house but it'd provide a better backhaul than trying to reach that far with standard satellites.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you. So I need to purchase two of these?
https://www.amazon.com/NETGEAR-multi-point-connectivity-Management-WBC502-100NAS/dp/B083R37W26
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you. Will pay it safe and get two of the Orbi. Ty.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unfortunately it did not work as the router is in an enclosed area and not near a window. So any chance you have another idea?
ty.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Research netgear airbridge
