- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Currently with Comcast and a 500 mbps plan. I have the RBK50 with one satellite. One of the kids rooms seems to have more issues with wifi due to distance and the number of walls the signal needs to go through. We do have a coax cable connection available in the room. Was wondering if I should get another satellite or if I can set up another modem in that room so I can direct connect the computer to an ethernet cable?
Appreciate your thoughts
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
correct. If you have moca in the xb6, then you'd just need a compatible adapter where you wanted service.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Extra satellite or second router
Most isp's only allow 1 modem unless you pay for another line.
But you could use a moca adapter (ethernet over coax)
Or add a satellite. either option would work.
The RBS40V has been on sale lately on amazon for pretty reasonable price. And it might be beneficial for the added coverage.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
If I use a moca adapter, other than the router connection do I need to use one at every cable connection or can I just use them where needed? Wasn't sure if I needed one where I have the main cable box.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
You can use one where ever needed. Just make sure the coax cables are linked. I've seen someone who had them not connected in the utility room and couldn't figure out why the system wouldn't work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
One more question as I'm thinking the moca adapters might be the way to go. If I set up the moca adapter on the Xfi modem and main Orbi, will the satellite require an adapter too? Just don't have a good spot for the satellite where there's a coax outlet.
Appreciate your help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I guess I'd like a little more clarity.
Moca adapters basically allow you to use a coax line as ethernet.
You only really need 2. One on the primary router and then 1 where you want a connection. You can add others if your wanting more hardwired connections somewhere.
Your orginal question was about adding another satellite. You might not need a moca adapter if you use another satellite.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The reason I want to move forward with the moca adapters is one of the rooms has a lot of lag and drops on zoom even with a seemingly good wifi signal. I was initially thinking another satellite but thought I would try the moca setup. Have an XB6 with Moca enabled, bridge mode disabled, wifi off and Orbi as router. With Moca built in the XB6, I'm assuming I don't need an adapter connected to the modem/router but just at the coax sources where needed. Is that correct?
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
