Antworten
Follower
FW 2.6.1.40 LAN connection not working
Hi there
Since the update I am not able to wire connect devices with my Orbi at all.
Orbi is set up in Router Modus and 2 satellites are wire connected. Also the satellites are sometimes loosing the connection.
Update process
1. Update First RBS
2. Update second RBS
3. Update RBR
Has anybody an idea how I can solve this?
Is anybody having similar issues or knows about?
Thank you
Christian
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Nachricht 1 von 2
Akzeptierte Lösungen
NETGEAR Moderator
Re: FW 2.6.1.40 LAN connection not working
Dear Customer,
You have contacted the German-speaking NETGEAR Community.
We are able to support you only in this particular language. If you decide to contact us in German, please rewrite your question and/or describe your issue/problem so everybody can understand and participate if they want.
Kind Regards,
DamianM
NETGEAR Community
Lösung in ursprünglichem Beitrag anzeigen
Nachricht 2 von 2
Alle Antworten
NETGEAR Moderator
Dear Customer,
Kind Regards,
DamianM
NETGEAR Community
Nachricht 2 von 2
Autoren, für die die meisten Kudos vergeben wurden
Diskussionsstatistiken
  • 1 Antwort
  • 41 Aufrufe
  • 0 Kudos
  • 2 in Unterhaltung
