- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Facebook and Instagram Intermittent Loading
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Facebook and Instagram Intermittent Loading
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Do you mean NAT Filter? Theres only IPv6 enable and disabled....
You can run NAT Filter OPEN and it's a different way to allow data to pass thru the firewall.
@becktoven wrote:
Was having same problem with IG & FB not loading pictures/posts etc. Changed IPV6 setting to OPEN from SECURED and it fixed the problem... at least immediately it did... I'm wondering whether or not that is prudent and what are the risks of changing that setting? Any help on that is appreciated!
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Under the 'ADVANCED SETUP' tab in the 'ADVANCED' settings, I click on the IPV6 option. At the bottom of that page it says:
IPv6 Filtering secured open
I changed the setting to OPEN from SECURED and that worked for the IG & FB problem. I confirmed (with the kids of course because I don't use either of them) it is still working this morning after changing the setting last night.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Do you have IPv6 natively supported from your ISP? If not then you can disable IPv6 all together, if you do then you can use IPv6 with Filtering set to OPEN if this clears up the issue for you. If you don't seem to use IPv6 then you can disable IPv6.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Yes, it's supported and changing the value to OPEN from secured fixed the problem with IG & FB. My question to the community was basically, what kind of risk is there changing the value from SECURED to OPEN for the IPv6 Filtering setting???
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Nominal. It's just using a differnt way to filter some data thru the router. I believe simimar to NAT Filter on IPv4.
Possible something that NG could review to see if they can make IG and FB work with IPv6 Fitler set to secure.
You might submit a support ticket and start some dialog with NG about this:
https://www.netgear.com/mynetgear/registration/login.aspx
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
A little more info... After contacting support, I found out my ISP does not support IPv6. Setting IPv6 Filtering to 'OPEN' fixed it for some reason. Perhaps this is the solution to others having the same issue with Facebook & InstaGram. Don't know but it worked for me...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
So if this is the case, then set the IPv6 back to secure, then DISABLE IPv6 all together. I presume the apps will work in this configuration as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I see no way of disabling IPv6 on my Orbi RBR50 unless I just don't understand the options. I only see "AUTO DETECT" and "AUTO CONFIG". I don't see any way to disable it from my choices....
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
There should be a check mark that would be seen, remove this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I'm missing a Check Box somewhere. I posted a pic of the IPv6 screen....
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Try a menu up under Setup. Is there an IPv6 listing there? There should be a IPv6 with a check box, enable or disable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Nothing in any of the SETUP choices for IPv4 or IPv6... Went through every tab in there.... It's all pretty basic with no detailed selection choices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Wonder if they removed that. Try setting local only?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I'm done... It's fixed... If my ISP ever getst IPv6, I'm ready for it LOL! Not going to pursue this any further as it's no longer an issue for me. Hope this helps someone else.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Ok good to hear. Ya, I'm still waiting on IPv6 with my ISP. Nothing anytime soon.
Enjoy for now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I think IP6 is configured (or disabled under ADVANCED, ADVANCED SETUP, IPV6 and then the INTERNET CONNECTION TYPE in the top right corner. it is a dropdown box where you can disable, Auto detect, and a bunch of other settings.
To disable IP6, select DISABLED>
My Equipment: Cox Cable (350Mb/35Mb), Orbi AX6000 (RBR850, 3 x RBS850) (2xWired backhaul), NG GS116PP Gigabit Smart Switch, Synology DS1019+ NAS
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
So I guess for all those having FB & IG issues you can either disable IPv6 or change the Filtering setting to 'OPEN' from 'SECURED' to get around it. I hope this helps others because this was a real mystery why just those two apps wouldn't work properly. Now they do
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Ok, seems odd why the change is now different.
Let us know how it goes with NG support.
@becktoven wrote:
Bad news. It's no longer working when I disabled IPv6. Also not working with the Filtering set to 'OPEN' now. When I set it back to enabled and the Filtering to 'SECURED' it works. Makes no sense at all. Going to have to open a case with support on this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi @Alan__Baban
Our support team is looking into this issue and would like to work with you. Please check your inbox.
Blanca
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I think i found the solution. It is quite simple actually. After many hour of talking to my ISP, I realize it is not the ISP problem but the Orbi defaults setting. Go to advanced set up, then IPv6 change that to pass through so it uses the ISP default one vs Orbi default setting. I am not an network expert so I don’t know the implications of me setting up this way but both FB and Instagram work perfectly right after me doing so.
My set up is:
Shaw Canada router on IP Passthrough mode.
Orbi Router mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Neat.
If other people can confirm that this works for them, this could be marked as Solved.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
