Reply
Feature Request: Orbi Satellite Ethernet Backhaul
KBeatty
Tutor
Re: Feature Request: Orbi Satellite Ethernet Backhaul
@SKK wrote:
When is this becoming a reality ? Been almost 1yr now since the above update.
Huh? Did you read any of the recent posts in this thread, or check any of the recent firmware updates, before posting? It is a reality.
Message 251 of 252
siegels
Initiate
Wired backhaul for satellites is good, and good update. Wired connecting for 2 routers on single network should be next.
Would have liked capacity to use a linked second router (even if wired) as a 2nd hub on same network since each router can only support three satellites.
Bottom line is that I should have bought the biggest strongest model with the biggest strongest satellites. Or, a different system that's more expandable. Rbk44 just doesn't get the job done.
Live and learn. Thanks for reply.
Model: RBK44| Orbi AC2200 WiFi System
Message 252 of 252
Top Contributors
Announcements
