- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Feedback After Updating to V:2.1.4.16 on RBK40 & Xbox issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm very pleased to say that NEW V 2.1.4.16 has bring an siginificant upgrade and fixes on my RBK40 Orbi router. It fixes alots of bugs, connection drop, intermidiate connection, no Internet connection, slow speed on pacific devices.
But one thing I'm having issue is with my Xbox One S. I don't know exectly what happened but for some reason my Xbox is getting slow download speed after updating to new firmware. On V:2.1.4.10 the xbox was getting excellent speed.
Also, I'm trying to stream my Xbox locally on my windows desktop w/ Netgear A6210 Wireless AC1200 WiFi adapter connected. But everytime when I do a Test Streaming on Xbox, I always get all "X" on all streaming quality. I'm able to stream my xbox but when I start playing high demanding game, I get an error message saying "Poor Connection" & the stream starts to lag and getting very long lettency.
- I have contact Xbox and they told me it's nothing wrong with Xbox. It's just something wrong with Orbi where router is unable to distrubute bandwidth evenly.
Xbox "Detailed network staticits" Result: Download 61.59 Mbps, Upload 29.02 Mbps, Latency 40 ms & Wireless strength 100%.
* I have enable Implicit BEAMFORMING & MU-MIMO. + IPV6 Auto detect. & Yes my ISP does support IPV6. But nothing work out no imporvement. I have also try to disable Implicit BEAMFORMING & MU-MIMO but nothing changes or nor a improvement.
Would anyone please assist on what's happening with my Xbox or Orbi?
Best,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Feedback After Updating to V:2.1.4.16 on RBK40 & Xbox issue
Try setting manual channel 1, 6 or 11 on 2.4ghz and any unused channel on 5Ghz.
Any other wifi neighbors near by? If so, how many?
Can you connect your xbox one up via LAN cable and test speeds?
Disable MIMO, Daisy Chain and Fast Roaming. You can leave beamforming enabled.
What is the distance between the xbox and router or satellite?
Where do you have the xbox connected too? Router or satellite?
Was a full reboot performend on the Orbi system. Power OFF for 1 minute then back on after upgrading FW?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for replying.
I have try switching different channels on both Ghz but nothing helps.
I have 15+ nghbors wifi nerby.
I can't connect my xbox hardwire because it's not possible. I have my xbox in living room & router game room.
My xbox one is connected to satellite and its about 240ft away.
Do you think it's problem either with Xbox One or Orbi Router hardware???
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
240feet? You sure about this?
What channels are you neighbors using?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes! The xbox is about 250ft away from satalite downstair & xbox is about 150ft away from Router in middle of the house upstiars.
My neighborhoods is using random wifi channals. Take a look at screenshots.
Now we are started to notice slow response time, slow loading time or sometimes wifi doesn't work and it just keep loading. Can you guys help me on that? * I have power cycling entire Orbi System + ISP modem but seeing little improvement but problem comes back. The problem started after couple weeks later since updating to V 2.1.4.16 * I've try changing channels but nothing helped.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Way too far away. Clients need to be with in 30-50 feet of the farthest router or satelllite signal.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
30 feet starting is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
@goldbondx wrote:
I continue to have random drops on both an Xbox one-s and Xbox one x. Distance to base is less than 30 feet with open 2nd floor. I don't feel the range is anywhere near advertised based on my IoT issues which we're non-existent with my old Asus router. Ring basic and pro have random connectivity issues. I have tried resets, spot beam changes and other options with no success. I am not happy with this product at all.
