Orbi WiFi 7 RBE973
Reply
Finding out ideal radio Tx
mith_it
Luminary
I have an RBK53, but I have to say it covers my home very well, in fact too well. I found that often I am getting decent wifi performance while being connected to the farthest satellite/router. I am thinking of reducing the TX of both 2.4 and 5Ghz wifi to reduce interface, reduce radiation on us and incentivize my devices to hop to a closer satellite more frequently.
Is there a recommendation on how to measure overlap so that I can try different TX levels and find the right middle ground?
Also, is there a way to maybe have different TX on the router and individual satellites? I know I have one that needs to cover a longer range than the other two devices
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 1 of 6
Accepted Solutions
mith_it
Luminary
Re: Finding out ideal radio Tx
With not too much fiddling I found that I can enable debug on both the router and satellites. I can then telnet to any device and manually set wl_tpscale for 2.4Ghz and wla_tpscale for 5ghz.
The devices take the setting immediately as I can see the change the router's Web UI. I haven't tested if it ACTUALLY changes the TX. At this point I'm still trying to figure out the ideal configuration for me.
I also have not tried rebooting the devices.
Message 3 of 6
All Replies
Guru
Since there isn't any power settings on the satellite, you'll have to play around with the power settings on the router. I presume if you reduce the power on the router, satellites may need to be placed a bit closer, which you'll also need to play around with there placement if you do this. You'll need to check the status on the connection seen on the router. Good or Poor and base your adjustments of that. Then check your devices to see how they are connected by doing some point to point connection and speed tests at various places around your home.
Message 2 of 6
mith_it
Luminary
Message 3 of 6
Guru
You can also change power settings under Advanced tab/Advaced Settings/Wireless.
I would reboot everything and test...
Good Luck.
Message 4 of 6
mith_it
Luminary
As per my original question what I'm trying to do is have different TX settings for each device (satellites and router)
Message 5 of 6
Guru
Are those settings working for you?
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1219 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
