foodpig1
Apr 26, 2022Aspirant
Fios Triple Play (Phone)
Hi,
Doing a setup for my parents. Personally I have an Orbi in AP mode with my fios Router in Bridge mode. My Orbi powers my wifi and I have no problem with wireless mini boxes and cable. My parents want to the do the same setup, but they have a VoIP with Fios. Will VOIP with Fios work?
foodpig1 wrote:
Hi,
Doing a setup for my parents. Personally I have an Orbi in AP mode with my fios Router in Bridge mode. <IF the FIOS router is in bridge mode, then your Orbi should be in Router mode, not AP mode. My Orbi powers my wifi and I have no problem with wireless mini boxes and cable. My parents want to the do the same setup, but they have a VoIP with Fios. Will VOIP with Fios work? Does the parents ISP modem/ONT have a built in router too? If so, Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
