- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Firmware 1.3.0.26
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Firmware 1.3.0.26
- Mark as New
- Bookmark
- Subscribe
- Permalink
Something is clearly wrong. Used to work flawlessly before the fw update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I see the same issue a reboot fixes it for me but the issue returns in 2 or 3 days then another reboot will temporary fix it...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Xbond
You could try to factory reset the router see if that corrects the issue or you could try to load the old firmware which you can get on the orbi support page and see if its the new firmware causing the issue.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bought an Orbi last night after a recommendation from a network salesman at BestBuy. He was knowledgable based on his answers to my questions and I trusted that he'd help fix our long running latency issues. The Orbi and his recommendation did not disappoint. Just after 12 hours of usage I'm completely sold on this device. So direct to the point... It's running the default initial firmware. It's working great. Should I update to the latest version or any version in between?
"Don't fix what isn't broke." is something I try to live by when it comes to tech; updated enough other routers in my day that I regreted later.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello GamerHonu
It is suggested to update but if you run into a problem you can manually revert back to a old firmware which is listed on the support page for orbi.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unforunately Orbi updated the main router itself overnight to 1.3.0.26. Found out because I woke up to no internet and an Orbi satellite on 1.1.0.16. Had to connect to LTE via my phone in order to download the satellite firmware and updated it manually. After a complete power cycle of my cable modem, I have internet. Anyway to stop Orbi from doing this again?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm noticing that the Orbi satellite is reporting no connection on the 2.4ghz band since updating the firmware to 1.3.0.26. Any ideas as to why? The Orbi satellite itself has no lights on reporting any errors but inside the status page it shows "2.4GHZ No Connection".
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have noticed the same, I am hoping it is a bug that the upcoming fw will address
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello GamerHonu
A new Firmware has been released have you updated your system to see if you are still having the issue?
DarrenM
- « Previous
- 1
- 2
- Next »
