Orbi WiFi 7 RBE973
Reply
Firmware 2.2.1.120 release notes
iain1248
Follower
My Orbi offered a firmware update to 2.2.1.120. Where can I find the release notes.
If I search Netgear.com, the lastest firmware show is 2.1.4.16 from April 2018.
FAIL
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 1 of 7
Guru
Re: Firmware 2.2.1.120 release notes
Will have to wait till they get posted.
Message 2 of 7
RocketSquirrel
Luminary
I assume you meant 2.2.1.210, and I imagine the release notes are the same as ChristineT posted elsewhere for 2.2.1.204. The difference between 204 and 210 is probably a last minute bug fix or two.
Release notes:
  • Includes bug fixes for stability and performance
  • Fixes Ethernet backhaul bug
  • Supports the Orbi Voice
  • Supports the Orbi Outdoor in Europe
Message 3 of 7
AmitR
NETGEAR Employee Retired
For RBK50, here it is:  https://kb.netgear.com/000060273/RBR50-RBS50-Firmware-Version-2-2-1-210
It's also available for other kits.
Orbi Product Management
Message 4 of 7
loomis1975
Luminary
Not finding it for RBS50Y or RBS40.
Nor the RBS40V for that matter, I do see a newer 2.2.1.62 for the RBS40V though, is that the newest one and the one to use?
I haven't seen a new firmware for the RBS50Y in a long time.
I would like confirmation of what firmware we should be running on the RBS50Y, RBS40, RBS40V to complement the RBS50 and RBR50 running 2.2.1.210.
Message 5 of 7
colingwalker
Guide
Update worked fine from the link... Even updated my 2 x plugin RBW30
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 6 of 7
Blanca_O
NETGEAR Moderator
Hi loomis1975,
Please see the latest firmware for the following devices:
RBS50Y : FW v2.2.1.204 (https://kb.netgear.com/000060276/RBS50Y-Firmware-Version-2-2-1-204)
RBS40 : FW v2.2.1.210 (https://kb.netgear.com/000060274/RBR40-RBS40-Firmware-Version-2-2-1-210)
RBS40V : FW v2.2.1.62 (https://kb.netgear.com/000060259/RBS40V-Firmware-Version-2-2-1-62)
These should work with your existing RBK50 Orbi system.
Blanca
Community Team
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 3439 views
  • 1 kudo
  • 7 in conversation
Announcements
Orbi WiFi 7
