- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Firmware 2.2.1.210 released as of 10/3/18
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Firmware 2.2.1.210 released as of 10/3/18
Plugged it in 5 feet away (same room, straight line) - still "poor"
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would presume this maybe a UI or status read issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The files for download for all Orbi's should be posted soon
~Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you Sir.
~Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have factory reset everything and started again, the Router GUI is completly wrong, showing devices connected to Router instead of Satellite, 2.4ghz instead of 5ghz. it's a mess.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Id re-read what i posted Furry. I tried all of those settings to NO avail.. and i tried a manual FW downgrade. but unit automatically uploads back up to .210!
I'm telling you: this FW is not well developed and still has a tonne of issues! Also, i'm not trying to do Ethernet backhaul. Quite the opposite. In fact i'm trying to make the units think the contrary. but evey time i plug an ethernet device on power start, the units when both satellites syncing up on power start, one of them goes in Wired Mode and kills all the wifi bandwidth
- Mark as New
- Bookmark
- Subscribe
- Permalink
Happening in different browsers?
Besure to clear the browser cache before entering into the routers web page...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I know you manually downgraded. Did you download the lastest version and manually update like BullyTerrier did and factory reset and set up from scratch? Seemed to work for him. Something to try.
Have you set up the wired mode from scratch by first adding the satellite via wireless, then once it's connected there, then connect the ethernet cable between the router and satellite, wait 5 minutes for the top led to turn on BLUE?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You are NOT getting it!
"Have you set up the wired mode from scratch by first adding the satellite via wireless, then once it's connected there, then connect the ethernet cable between the router and satellite, wait 5 minutes for the top led to turn on BLUE?"
I'm NOT trying to set up the Wired Mode! I want them to sync up 5G even if a network device (NAS!) is plugged in on a satellite! But satellite INSIST on starting up as wired mode even though it HAS synced in 5G, but shows incorrectly. THEN because of that, it kills ALL wifi bandwidth 3fold.
ONLY WAY TO OVERCOME is to start them up WITHOUT any ethernet plugged at the back of ANY RBK53 unit, and then once all in 5G, then plug network devices. again, i insist, i am NOT trying to set them up in Ethernet backhaul AT ALL WHATSOEVER.
- Mark as New
- Bookmark
- Subscribe
- Permalink
you are also not getting this: "I know you manually downgraded. Did you download the lastest version and manually update like BullyTerrier did and factory reset and set up from scratch? "
I have NOT been able to manually downgrade it, as everytime I do this, units INSIST on auto update back up themselves to latest .210 FW
And yes, with just 210 FW I did what bully terrier suggested, as i read his post before i and posted mine, and tried his approach.
- Mark as New
- Bookmark
- Subscribe
- Permalink
And if you hold in the reset button on the satellite till the top led turns on Amber, then let go, wait for the WHITE led to pulsate slowly, then add the satellite to the router, what happens here. Same problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
"And if you hold in the reset button on the satellite till the top led turns on Amber, then let go, wait for the WHITE led to pulsate slowly, then add the satellite to the router, what happens here. Same problem?"
Yep! Same, same: Next time the RBK53 machines reboot with some ethernet stuff plugged at the back of the satellites, at least one or the other (but not both) then will show in dashboard as Wired Mode. If this happens, my ISP speed broadcast through the Wifi will go from 350-380Mbps down to 35-50Mbps.
If you, instead, power up the RBK53 clean of any network devices plugged in any of the LAN ports (of either the router or Satellites), then Wifi goes back up to the speed it should, and remains constant at 350-380Mbps.
I have tried different LAN ports as well, and different boot up orders for two solid days.
As long as there is stuff plugged at the back of a satellite, when you try and sync 2 of these, at least one of these satellites will sync config in Wired Mode. (Of course, it doesn't as this is impossble as there is no ethernet direct between satellites - it is just what it displays!).. so, it still is a 5G connection between satellites, but it shows wrongly in dashboard, and then you can tell the sync or something is wrong - as it is when you then get these low reduced 35-50Mbps speeds only from the ISP over Wifi.
Once you get them BOTH satellites synced up via 5G and showing as such on Dashboard, then you can plug network devices as normal, and these will work fine, of course. It just seems to only throw the overall controlling software (FW), when you try and power them up from scratch with stuff plugged at the back.
It is buggered because say you have a power cut, or one of the machines get stuck and you want to reboot just that one, you then have to make sure to undo all cables before completeing that process. If you have a power cut and you don't realise, you will suffer poorer speeds until you check and find out whats wrong, and then reboot/power up the system clean.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I also have some devices plugged in via ethernet showing up as hooked to the router on its GUI, instead of correctly being reported as wired onto the satellite.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So is anyone else getting 5ghz connection as unkown even if your do a manual firmware update with a factory reset?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Possile this may have been intended as a more simple way to show connected devices on the router. Maybe NG support can provide some behavior information.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It’s enabled the guest network without my knowledge while the GUI says it’s off. Had to enable it and disable it to make sure it’s off.
Very buggy firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank for letting us know. Did you just update FW and continue or factory reset the router and set up from scratch?
What browser are you using?
@jblack68 wrote:
Another bug:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you log into the Satellites UI and see whats connected at the satellite?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
