Orbi WiFi 7 RBE973
Reply
Firmware Manual Update Page Not Showing Router
MiddKid
Guide
Strange issue I'm trying to solve while visiting my 80 year old parents' house for a week...
They have a basic RBR750/RBS750 system. 1 router, 3 satellites. When I arrived there were three different firmwares so I went into the manual update page and manually updated each satellite. They are all now running 4.6.8.5. The router, however, is still on 4.6.8.2 and the automatic update page says no firmware update available. Problem is when I go to the manual update page only the satellites are listed, not the router. When I did this on my own home network, the router was there as well. Stumped by this one...how can I get the router to appear on the manual update page?
Message 1 of 10
Accepted Solutions
CrimpOn
Guru
Re: Firmware Manual Update Page Not Showing Router
Since this is a Manual Update, you have already downloaded the new image file. Just follow the directions.  For the router, click on Browse to find the image file and upload it.  For satellites, you have to select which one to update, so there is a table to choose from.
Message 6 of 10
All Replies
Guru
What browser are you using? Try MS Edge or Firefox?
There should be a Manual Tab seen on the RBRs web page...
Message 2 of 10
MiddKid
Guide
Tried both Chrome and Safari. And yes, there is a "Manual Update" tab which I click on. But then the table that shows the available devices only shows the 3 satellites and not the router. Strange.
Message 3 of 10
CrimpOn
Guru
This part of the Manual Update page is missing?
Message 4 of 10
MiddKid
Guide
No, that's there. The router isn't in the chart, just the satellites. See attached.
Message 5 of 10
CrimpOn
Guru
Message 6 of 10
Guru
The router won't be in that list. Thats only for the RBS. Manual Updates take place for the RBR on the Manual tab.
Message 7 of 10
Guru
The router won't be in the chart. just the satellites.
For the router, you'll use the arrow'd section that @CrimpOn highlighted.
Message 8 of 10
MiddKid
Guide
I'm an idiot. I thought it had to be on the list with the checkbox next to it. Bingo. Updated! Thanks.
Message 9 of 10
Guru
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1469 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
