- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Firmware Roll Back Question
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since auto update can not be disabled is there the ability to roll back to a previous version? Also would it be possible to add a schedule time of day for an update? I only ask b/c a router reboot at the wrong time could have a negitive impact something you are doing.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
hi
it would be pretty useless to roll back as the orbi would just try and update its self automatically afterwards
i do agree there should be a setting to select when its done and will ask the beta team to investigate if it can be added
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
hi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Firmware Roll Back Question
Your right on the roll back...LOL
Thanks for running schedule function past beta team.
