Orbi WiFi 7 RBE973
Reply
Firmware Upate 2.0.1.4
pettusta
Follower
I’m currently on 2.1.2.18 on the RBR50/RBS50, and I see there is a firmware update on the support page showing version 2.0.1.4. That seems like it may be an older release, which makes me wonder if I should avoid installing it. Has anyone else installed it, or is this just for a specific issue?
Message 1 of 2
Retired_Member
Not applicable
Re: Firmware Upate 2.0.1.4
They've stepped back.  2.0.1.4 is now considered the latest version.  If your system is running OK with what you have, best advice is leave it alone.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 867 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
