Reply
Highlighted
Follower
Firmware Updates
I recently purchase an orbi RBK50.  When setting up i was having trouble linking router and satellite.  I have internet and wifi through orbi router but it would not link dispite several attemps.  I did a reset on both the router and satallite that did not help.  In my frustration or haste i updated the firmware on the router.
Without being able to link the satellite i can not see the firmware it is currently running.  I have logged into robilogin.net but there is no satellite listed so i can not do a manual update there either.  Is there anything i can do?  i am not extremely tech savy so please reply as such if possible.
Thanks
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 4
Highlighted
Guru
Re: Firmware Updates
You need to update the satellite FW first. You may have to downgrade the router back, then get the satellite connected long enough to upgrade the FW there first, then upgrade the router last.
I recommend manually applying FW updates by downloading files needed and using IE11 or FF browser. Do a factory reset once all is updated and setup from scratch.
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK50 v2.7.0.70(AP Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 4
Highlighted
Apprentice
You need to return this back to the store as soon as possible and get another system.  Tons of issues with firmware as you should be able to tell in this forum.  I wish I could return mine but unfortunately I'm past my return window.
Message 3 of 4
Highlighted
Guru
Doesn't mean OP will have same issues or any issues. Let the user get his set up before assuming he will have problems.
IF your having problems, make a new post and give details to your problems. Maybe we can help you get yours going better.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1063 views
  • 2 kudos
  • 3 in conversation
Announcements
