- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Firmware V1.12.0.18 Discussion
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Firmware V1.12.0.18 Discussion
@scornwell wrote:Is anyone who is reporting success with the latest beta actually using the routing functions of their Orbi?
It's seems madness to me to purchase a $500 Orbi kit and only use it as an access point when you could have acheived the same by adding a second, much cheaper, WiFi router to your existing setup. Especially those with internet connections which are unable to take advantage of Orbi's backhaul.
Netgear just added a new extender that uses the Orbi backhaul as a model that should give similar results to the Orbi when used with a router with 3 radios. I've tried many AP's in the past, and without the extra radios and dedicated bandwidth of the Orbi, never had good enough results. On the other hand, the Orbi as an AP gives me full strength, full speed wireless all over my house. Had the new Netgear extender been available when I got the Orbi, I would have tried it despite not having a 3-radio router. Even with two radios in the router, the dedicated backhaul radio in the new extender would be helpful.
Anyways, I don't disagree that it's crazy, but it works so well *smile*...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Both are fair answers, but the target market for this device seems to be the non-technical, not people who are likely to set up a dedicated router. Though I guess they're the same people who will be quite happy plugging this into their ISPs router, so maybe I'm the odd one out here!
There's no denying Orbi has a fantastic backhaul when it's all working correctly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
you need to raise a support ticket and ask for it
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Can you tell me how to create a support ticket and ask for the beta firmware if I'm past my complimentary 90 day support? thanks in advance......
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
https://www.netgear.com/support/contact.aspx
If you are beyond the 90 day you will need to purchase support. I think its the Gearhead option.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I'd like to know what magical routing capabilities you're looking for in a home router that can't be filled by the Orbi. I went from an R7000 running XWRT (and prior to that DD-WRT) to the Orbi and I've not missed any routing duties that the R7000 was doing.
Now if you're runnig a home lab or a very complex network then maybe but if you are, the majority of consumer hardware is probably not for you.
Using the Orbi as an AP seems like a huge waste of money.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
100% disagree, If it's a waste of money can you show me a cheaper AP that'll handle my gig up/down connection and cover the whole flat/house at the same time?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Handling a gigabit up/down on a LAN can be done by ANY AP so I don't see how that's relevant.
As for coverage, sure, grab yourself literally any mesh system from Google, Eero, TP-Link, etc and you'll be saving between $50-100.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
ok let me rephrase, how can I get the max speed out of my wifi with google wifi or eero or linksys velop for that matter which I just returned due to it being 100Mbps-200Mbps up/down slower? and no, not every AP will handle a gig up/down. I tried many in the past on just a 300Mbps connection which failed to get above 200Mbps
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Well let's take a step back then. Are you testing your speed being hardwired to the RBR, being connected wirelessly to the RBR, hardwired to a satellite, or connected wirelessly to the satellite?
Hardwired to the RBR I expect full gigabit up/down (or the closest consumer-grade approximation thereof).
Wireless to the RBR I expect somewhere around 60% of the max speed so figure ~520Mbps
Hardwired to the satellite I'd expect aroud 575Mbps
Wireless to the satellite I'd expect to look somewhat like a wireless connection to the RBR with an extra latency hop so around 520Mbps.
Now this is all assuming you're within line of sight and no other devices are talking at the same time.
I'd expect a Google WiFi or Eero to perform the same on the hardwired portion and at least similarly when conected to the main unit (the one connected to your WAN or LAN.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I'm talking about the wireless speed here
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@tomsliwowski wrote:I'd like to know what magical routing capabilities you're looking for in a home router that can't be filled by the Orbi. I went from an R7000 running XWRT (and prior to that DD-WRT) to the Orbi and I've not missed any routing duties that the R7000 was doing.
I use Orbi in AP mode, because I need a router with IPSEC site-to-site VPN capability and with L2TP remote access VPN capability. Orbi has neither of those features.
Using Orbi in AP mode is not a waste of money at all. I use Orbi for it's single discriminating feature--the wireless backhaul--and that feature is available in AP mode. I'm using Orbi because I cannot easily run wired Ethernet. If I could run wires I would use something else.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Right, your needs are almost certainly beyond the audience that the Orbi is aimed at. The people that I've personally interacted with needed a normal home router which had really good WiFi coverage. Hell, I bought it because I needed a stronger signal in an aluminum sunroom and ports for a couple of computers near it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@cinek wrote:I'm talking about the wireless speed here
Let's start with acknowledging that Orbi is towards the top part of most tests but accordin to smallnetbuilder, others aren't so bad:
The 5GHz tests show relatively low variance and 2.4GHz are a bit more mixed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Again, I'm using orbi for its strength, strong backhaul, wifi speed and coverage. Orbi is one of the fastest out there. Routing is not Orbi's strength, its meant for home networks so its not really much of a router (at least the functions are not exposed to the home user for that).
I use a sophos UTM box Which lets me do a lot more things including a lot more security than what an Orbi can do. Servers, etc.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Nope, Orbi is faster than most AP's out there, thats why I'm using it as an AP only as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@spinkick wrote:Again, I'm using orbi for its strength, strong backhaul, wifi speed and coverage. Orbi is one of the fastest out there. Routing is not Orbi's strength, its meant for home networks so its not really much of a router (at least the functions are not exposed to the home user for that).
I'm really curious what special routing is needed. I'm not trying to be rude but I just don't see what real world needs would be. Like I know for business grade hardware the needs/capabilities are much much greater but for a normal house I honestly can't see what those would be.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
For me, intrusion prevention, antivirus at the gateway. I am a computer consultant so I'm more interested in network security than most, I suppose.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hmmm...Checked for new firmware, found it and flashed it. As a result, Orbi router and satellite have just been updated to v2.0.0.72...assume that this is the next official release after v1.12.
Doing fine so far, but hasn't been very long yet. Expecting it to be fine, since v2.0.0.64 was doing fine as well.
Time will tell *smile*. Just found this:
https://community.netgear.com/t5/Orbi/OrbiOS-2-0-availability/m-p/1368730#M13446
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Nice try guys but a fail. I upgraded to version 2 and within 2 hours everything was locked up. No internet access or WiFi access. Same as the previous versions. Until you perfect the firmware, the system is garbage. I have an expensive 6 month old paper weight. Not a complex network. One satellite and 22 devices connected to a Spectrum cable network thru a SB3400 modem.
It is obvious you have no clue as to what is wrong with these units. They should be recalled.
I am going to post to Amazon and other boards the truth about Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Its perplexing how some people have 0 problems and others have total trainwrecks. There has to be something causing this. My system is flawless, and I feel for you guys with issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@tpgall wrote:Nice try guys but a fail. I upgraded to version 2 and within 2 hours everything was locked up. No internet access or WiFi access. Same as the previous versions. Until you perfect the firmware, the system is garbage. I have an expensive 6 month old paper weight. Not a complex network. One satellite and 22 devices connected to a Spectrum cable network thru a SB3400 modem.
I can understand your frustration but have you tried a few basic things?
- Done a hard reset of both base and satellite - Use a paper clip and press the buttons on the back?
- Tried your network with a few basic devices (PC/TV)? - have you considered you might have a device that is causing overly chatty and crashing yoru network?
- Reset your cable model before you restarted the Oribi system? - Maybe your cable company has a new flash of their own that isnt playing nice with the Orbi
With this new FW there are very few people complaining which leads me to think its something ON your network or you have a bad Orbi and should do an RMA.
