Orbi WiFi 7 RBE973
Reply
Firmware Version 2.3.1.44 Update Failed solved - sort of
timch
Luminary
I have an RBR50,RBS50 AND RBS40 and the latest update to Firmware Version 2.3.1.44 was failing from both apps and the web gui giving the message update failed against the RBS40.  I assume there is a bug of some sort in the error checking protocol as RBS40 has no updated firmware yet.  I sorted it out by switching off the RBS40 starting the update and then switching it back on. I didn’t wait for the update to complete before switching back on and the whole system came back to normal functionality. All working fine now, and as always, I didn’t factory reset!!  I post this in case anybody else has the same issue.
Message 1 of 3
BBB73
Apprentice
Re: Firmware Version 2.3.1.44 Update Failed solved - sort of
Smart! I also have the RBR50, RBS50 and RBS40. Via the web the update failed but via the IOS app it worked.
Message 2 of 3
Guru
Make sure your system is updated to v32 first by manually installling v212 and v32 files, then try using the UI to update to v44.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1584 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
