Orbi WiFi 7 RBE973
Reply
Firmware update (automatic, through Orbi app or manual with connect laptop)
aruit
Guide
My current setup is an Orbi Router with 3 Satellites.
Two Satellites are connectes to the Router and the third Satellite is connect to another Satellite.
I noticed that there is a new firmware update 2.1.4.16, but all my Orbi's are still on v2.1.4.10.
Why is my system not automatically detecting that there is a new firmware available?
When I do a check for updates in Router Settings on my Orbi App (version 2.2.0.363), I get the message "Wait about five minutes while your orbi checks for new firmware", änd after a few minutes I get the response "Your system is up-to-date" or it stays in the previous messages for ever, but without a firmware update.
Why is my system not updating through the Orbi App?
So, the only way to update the system is manually, with a laptop connected to the Orbi system.
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System, RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 1 of 7
Guru
Re: Firmware update (automatic, through Orbi app or manual with connect laptop)
NG may have pulled v.16 from the auto update servers. I would not worry about.
If your systems is working, then don't fix it. Your not gaining anything with attemping an update.
Message 2 of 7
aruit
Guide
Yes, my system is working OK, but I did receive an email from Netgear:
Don't Forget! We've Enhanced Your RBR50 Product Security. Update to the latest firmware!
Message 3 of 7
Guru
You'll be fine.
Message 4 of 7
aruit
Guide
I know that it will be fine, but I had expected that the functionality of Firmware update was working in the Orbi App, when the new Firmware is to download on the website of Netgear.
Message 5 of 7
Guru
You might ask the forum Moderator if there is a problem with the app.
@DarrenM
Message 6 of 7
RocketSquirrel
Luminary
I updated my firmware manually. My reasoning is, that if the update software is as bad as the Orbi firmware, I don't want to trust it. My manual update went perfectly.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2942 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
