Reply
Firmware update disabled streaming
MCatherman
The latest firmware update, V2.3.1.60, has disabled my streaming capabilities. Any known fixes or how I can revert to the previous firmware version?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 5
Accepted Solutions
Guru
Re: Firmware update disabled streaming
Try a factory reset on the system and setup from scratch. Walk thru the setup wizard and do not load a prior saved backup configuration from file. Do a new clean setup.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v3.2.18.223/SRK30 V3.2.33.106)
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, RBK50, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 3 of 5
All Replies
SW_
Prodigy
Prodigy
@MCatherman, you can revert to a previous version by re-installing your previous version over the current version.  By the way, what streaming issue did you run into?  Perhaps, someone might be able to help if they understand the issues better.
Message 2 of 5
Guru
Message 3 of 5
MCatherman
Thanks for the info. I am getting a message indicating I'm not connected to the internet. It's happening my mobile devices for Prime Video and DirecTV.
Message 4 of 5
Guru
Reboot the devices and re-connect them to the Orbi...
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 711 views
  • 1 kudo
  • 3 in conversation
Announcements
