Reply
Fixed IPs?
petercw2
Luminary
Fixed IPs?
I'm investigating this device and due to home automation I have many fixed network IP addresses assigned for different devices (home theater, NAS, etc).  Wondering if Orbi will allow me to do that as well and if Orbi comes as a 10.1.1.1 setup, and if not allows you to switch it to that range?  Thanks!
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
st_shaw
Master
Re: Fixed IPs?
You can reserve an IP address for a particular device based on the device's MAC address, such that the Orbi DHCP server will always hand-out that address.
By default Orbi uses 192.168.1.1/24 for the LAN.  You can change the LAN subnet if desired.
The manual is here:
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2337 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
