- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Force Satellite To Specific Device
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I bought additional Orbi Satellite AC2200 to connect to our RBR40 router. Our wifi setup now have 2 satellites. The devices, (laptop, security cameras, and doorbell) nearest to the new satellites are still connecting to either the farthest satellite or to the RBR40 router.
How can I force the devices to connect to the nearest satellite?
I tried turning off the farthest satellite for a moment, but as soon as I turn it back on, the devices would again connect to it or directly to the router.
I read another post similar to my issue but the suggested option is inconclusive.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Force Satellite To Specific Device
@ydlazkov wrote:Hi,
Not sure why you want to do this. The Orbi mesh is suppose to know what's best. I doubt even if you could, would you see any increase in speed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is not always possible to get devices to connect where we want them to. You can try the experiment another way: turn off the DEVICE (which implies it no longer has a WiFi MAC address that it is waiting to reappear) then turn the device back on. There is supposed to be a negotiation between the device and APs where the Device chooses which one it will connect to.
The previous poster is correct. Is it working? Be greatful not to be troubleshooting the damn thing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
@ydlazkov wrote:Hi,
