Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Forcing devices to always connect to a specific satellite / router
- Mark as New
- Bookmark
- Subscribe
- Permalink
2018-09-09
05:39 AM
2018-09-09
05:39 AM
Hello all,
I can’t seem to find a definitive answer to this but I have two wireless devices that I want to always connect to the RBR50 router and one wireless device I want to always connect to one specific satellite. I have the MAC addresses of all these devices, is there a way to do this that anyone can suggest or has successfully tested?
Many thanks in advance to anyone who can help!
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 4
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2018-09-09
07:43 AM
2018-09-09
07:43 AM
Re: Forcing devices to always connect to a specific satellite / router
I'm also looking for this answer.
I have a RBK53 and i bought another additional Satelitte.
1 Router
3 Satelittes
QUESTION
1. Any way to Force link Certain Satelittes to link to another. My Problem. Say my satelittes are based on distance.
Router - 1 - 2 - 3 (1 - closest, 3 furthest from router. I want satelitte(3) to link to satelitte(2) but instead it links to (1) or router making my signal poor. anyway to fix this?
2. Any way to force a device to lock on or connect to a specific satelitte or the closest one with strongest signal. Although i have a satelitte just few feet from me. its connected to one that is 20feet away.
Thanks. Appreciate any help that i can get.
1 Router
3 Satelittes
QUESTION
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2018-09-09
08:45 AM
2018-09-09
08:45 AM
You cannot force devices to lock to a specific access point. The client devices roam based on the signals they see available. Client devices won't roam to another access point, if the signals is strong enough from the current access point, nor should they need to roam.
If your Orbi units are so close together that the signals overlap too much, then reducing transmit power, especially on the 2.4 GHz band, should help with roaming.
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2018-09-10
06:53 AM
2018-09-10
06:53 AM
30 feet is recommended in between routetr and satellite to begin with depending upon building materials.
Message 4 of 4
Announcements
