Orbi WiFi 7 RBE973
Reply
Frequent network drop on Orbi RBK50
Moffy
Follower
ok have a RBK50 home setup latest firmwear and keep haveing network drops WIFI and wired ....have factory restet and still the same any help would be appreciated you dont seem to get help from netgear after 90 days ......thanks
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
Guru
Re: Frequent network drop on Orbi RBK50
Any other wifi neighbors near by? If so, how many?
What channels are you using? Try manual channels 1, 6 or 11 on 2.4Ghz and other unused channels on 5Ghz.
Disable MIMO, Daisy Chain and Fast Roaming.
Whats the distances between the router and satellites.
Whats the distances between the router, satellite and TV?
What is the Mfr and model# of the ISP modem the Orbi is connected too? Built in router here by chance?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 746 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
