Orbi WiFi 7 RBE973
Reply
Got email to upgrade RBW30 to v2.3.0.4 and system says V2.2.1.204 is latest firmware
Charlievuezone
Initiate
Sugned in on my PC and ran 192.168.1.1 as ADMIN and software says "No new firmware version available."
What should I do ?
Message 1 of 3
Guru
Re: Got email to upgrade RBW30 to v2.3.0.4 and system says V2.2.1.204 is latest firmware
you can upgrade manually. it might not be pushed out to the server yet. the most current is 2.3.0.4.  you can download it directly and manually upgrade it via the procedure described below.
https://kb.netgear.com/000060601/RBW30-Firmware-Version-2-3-0-4
Manually Update Satellite Firmware
To manually update your satellite's firmware:
1. Launch a web browser from a computer or mobile device that is connected to your
Orbi network.
2. Enter orbilogin.com.
A login window opens.
3. Enter the router admin user name and password.
The user name is admin. The password is the one that you specified the first time
that you logged in. The user name and password are case-sensitive.
The BASIC Home page displays.
4. Select ADVANCED > Administration > Firmware Update > Manual Update.
The Firmware Update page displays.
5. Select the check box next to your satellite’s model name.
6. Click the Update button.
The Orbi satellite Firmware Update window opens.
7. If the browser ask you for the admin password, enter the same password that you
entered for the router.
Manage Your Network 97 User Manual
Orbi WiFi System
8. Click the BROWSE button.
9. Locate and select the satellite firmware file that you downloaded.
The firmware file name ends in .img or .chk.
10. Click the UPLOAD button.
It takes a few minutes to complete the process.
11. After Orbi satellite finishes updating, select Status and double-check the firmware
version on the Status page.
The firmware on your Orbi satellite is updated.
Message 2 of 3
Guru
Manully download and install the FW file.
What should I do ?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 717 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
