Reply
Guest Access Issues
sdunnin
Luminary
Guest Access Issues
When enabling the Guest Network on the Orbi (Firmware Version V1.4.0.34) there are a couple of troubling issues.
  1. I have SSID Broadcast selected and WPA2-PSK [AES] security selected. When scanning Wifi 2 SSID's are being broadcast for the Network name I chose for the Guest Network. One is secured and one is completely open. Even with the WPA option checked there is an open SSID that anyone can connect to. This is bad.
  2. The option "Allow guests to see each other and access my local network" is checked and greyed out. I cannot turn it off which I assume means that anyone connecting on the Open wifi network will have access to
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 9
RonV42
Luminary
Re: Guest Access Issues
Are you running in router mode or access point mode?
Message 2 of 9
sdunnin
Luminary
AP Mode
Message 3 of 9
JMU1998
Luminary
I have same issue in AP mode also, for now I had to go back to .16 which is the most stable for now
Message 4 of 9
rhester72
Virtuoso
There is no guest isolation in AP mode.
Rodney
Message 5 of 9
RonV42
Luminary
I think they need to spell this out in big bold letters that AP mode dosn't support guest isolation.
Message 6 of 9
sdunnin
Luminary
Is that a feature or a bug?
Message 7 of 9
RonV42
Luminary
Feature,  in AP mode there is no network traffic isolation that is why the checkbox is set and can't be unchecked
Message 8 of 9
sdunnin
Luminary
Sounds more like a liability than a feature. I don't think anyone would really want to run a guest network without being able to isolate traffic. I have another wireless router than can do this as an AP.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 2585 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
