- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Guest Network not broadcasting through Satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
Both Satellite and Router are up-to-date with hte current firmware. what's odd is that the satellite (which is backhauled through ethernet) is showing offline in the app (but connected directly shows it's up and running (and I don't have any issues connecting with it)... except for guest. It looks as though the guest wifi isn't being broadcast through the satellite even though it is working correctly on the router. Thoughts?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@VFMass wrote:
V2.3.1.60
I think this is one of the issues introduced in 2.3.1.60. I think that something is wrong in the Satellite software. Please try the following:
- Power off the Satellite. Keep the Ethernet backhaul connected.
- Go to "Attached Devices" in the web GUI, and click on "Remove" or "Forget" device for the Satellite that you powered off.
- Now power on the Satellite and then use a paper clip to factory reset it.
- When the Satellite comes up press the Sync button on the Router and then on the Satellite to connect the Satellite to the Router
- That's it, when the Satellite comes up things will continue working as they should!
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Guest Network not broadcasting through Satellite
Has a factory reset and setup from scratch been performed since updating FW? No loading of a saved backup config file?
Is Daisy Chain enabled. It should be disabled for ethernet connected RBSs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's a new buy, so the firmware came loaded. I went into the settings and disabled daisychain (I'm assuming if I add a second satellite I will need to have it connected via ethernet now?) but the satellite is still not broadcasting the guest network. In the settings it shows the SSID for 2.4 and 5 primary, but not guest.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do a factory reset on the RBS and re-add it. This time add it via wireless only and see if the Guest Network is seen while it's wireless connected...
What FW version is currently loaded on the system?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Most of the product I purchase "new" have been sitting in the supply chain for some time, and almost always have firmware that is out of date. Orbi's, IP cameras, Smart Switches, Android phones, laptops, etc.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did a factory reset and connected it wirelessly—it seems to work with the guest network. Interestingly enough, when I connect the ethernet it doesn't work. so, I guess I'll need to just daisychain without ethernet?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I will note that the "backhaul status" is poor.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's in my office building which includes thick walls—which is why I had the satellite connected via ethernet. Is there any reason for the guest to stop working when the ethernet is connected?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So you don't get guest network at the RBS when ethernet connected? I presume guest network is running at the RBR when the RBS is ethernet connected?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@VFMass wrote:
V2.3.1.60
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am surprised that there is such a significant bug that hasn't been resolved yet. Thank you for this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working. Enjoy.
