Reply
Guest Wifi Network not isolating devices
Aspenthedon
So I've been reading that orbi does not properly segment the guest wifi is this still true? Because there doesn't seem to be much support in the thread. Also what are my options if still not fixed I am implementing a lot of iot devices and as you know don't want them on my main. Thanks in advance
Message 1 of 2
Guru
Re: CAN SOME DEVS OR ADMINS PLS RESPOND
The first wave to be released are only for the RBR50 and RBS50, which is used in the RBK50 and RBK53 (Costco) kits.
New beta FW avaialble. Get it while its hot of the press:
Might fix this issue...
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 608 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
