- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Guest network not working on the RBR50 + RBW30 mesh system and 2.4Ghz network issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had the Orbi mesh system that includes the RBR50 router and 2 satellite RBW30 about 2 months. I've upgraded to the firmware version 2.5.1.8. I have couple IOT devices (Nest Yale X Lock, Nest thermostat) that only connect to the 2.4Ghz and every couple days, they go offline so I have to reboot the Orbi system couple times to get the devices to be online again.
Another issue that I have since day 1 was that the Guest Network never works. I can connect to it but couldn't get to the internet.
Anyone having the same issues? And suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Guest network not working on the RBR50 + RBW30 mesh system and 2.4Ghz network issue.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
@hphan1229 wrote:I had the Orbi mesh system that includes the RBR50 router and 2 satellite RBW30 about 2 months. I've upgraded to the firmware version 2.5.1.8. I have couple IOT devices (Nest Yale X Lock, Nest thermostat) that only connect to the 2.4Ghz and every couple days, they go offline so I have to reboot the Orbi system couple times to get the devices to be online again.
I assume you know they have gone offline because the smartphone app reports it cannot reach them?
When this happens, does the Orbi show them connected?Since these devices are sort of "permanent", I would assign them a specific IP address in the Advanced Tab, Setup, LAN Setup screen. Do they have assigned IP's?
When a device connectes to the guest network, does the Orbi "Attached Devices" show it connected to "Guest"?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Regarding the Guest Network, i have the same issue. I have multiple models of Satellites, the one that is causing the issue for Guest WiFi is the RBW30, disconnect that from the power and your guest network will start working! With it connected and if your device has roamed onto that Satelitte then your guest will get an IP address and everything will look fine but you wont be able to get any Internet Access or ping any internal (which is expected on guest) or external (which should work) IP addresses.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Another issue that I have since day 1 was that the Guest Network never works. aboutpetguide I can connect to it but couldn't get to the internet.
I am having the same issue, did you resolve it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You may have noticed that the two posts in February about problems with the Guest network have never been followed up. It appears to me that the people who started this discussion are no longer participating.
My sense is that you are more likely to get a resolution by starting a new post with a description of the situation. i.e. which Orbi models, with which firmware version. A device connects to the Orbi "guest" network and receives an error message instead of a connection?
The more specifics, the more likely it is that someone will have a useful comment.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's been busy so I have not had time to deal with this but this problem still persists. Now, I am also experiencing another problem that no devices can access the wifi once every couple days until I reboot the router. I have not dealt with the Guest network either.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not yet. I have tried other suggestions that I found online but didn't seem to help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'll try to see if this works.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:What is the Mfr and model# of the ISP modem the NG router is connected too?
SURFBoard SB6183
What is the size of your home? Sq Ft?3300 sqft
30-40 ft
I've tried channel 1, 6, and 11 on 2.4Ghz and 48 on 5ghz
I can detect about 6 other wifi SIDs from the neighbors.
Done this but no helps.
Not yet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a factory reset, I believe this corrected another users problem with Guest Network not working on theres a while back.
SURFBoard SB6183
30-40 ft
Not yet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@hphan1229 wrote:I've upgraded to the firmware version 2.5.1.8.
Why??
Lots of problems with 2.5.1.8. Many have reverted back.
