- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Guest network
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi I couldn't find the Guest Network function in my RBR50 menu. I saw people complainig for the guest network being disruptive on ORBI systems. Does anybody knows anything about it? Are they planning to solve the problem and reactivate the guest network function in the next firmware?
Thank you.
Dario
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
What firmware are your Orbi's on? As far as I know version 2.0.x.x supports the guest network just fine. The complaints being that you cannot turn it off and on without disrupting the main network as the router seems to reboot when you do that.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Guest network
I installed the latest firmware upgrade manually and everything works just fine now. I don't actually need to switch on and off the guest network, therefore the forced disruptive system reload issue doesn't affect me.
Thank you for your support.
Dario
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Guest network
Guest network functions to provide Internet access to devices. It does not provide complete isolation when the Orbi is used in AP mode however.
