Reply
Guest network
dchbbc
Apprentice
Guest network
I have a RBR40 with 3 satellites. I'm not sure why this model doesn't show up as a choice. I made a guest network. I have it disabled but I want to delete it completely. I can't find how to do this. Any help?
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 1 of 8
Guru
Re: Guest network
You need to log in to the routers web page using a PC or laptop and a web browser to disable Guest Network. SHould be under the Basic Tab or Advanced Tab.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.1/RBK50 v2.7.2.104(WW)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 2 of 8
dchbbc
Apprentice
Re: Guest network
Hi. Thanks. I did that already and there is no disable, at least on mine. I tried to delete the name and password but it won't save without them. I guess I'll just have to leave it.
Message 3 of 8
Guru
Re: Guest network
What browser are you using? There should be a check mark to enable or disable Guest Network.
You can do a factory reset ON the RBR and setup from scratch. Guest Network is disabled by default if I remember correctly.
Message 4 of 8
dchbbc
Apprentice
Re: Guest network
I'm on Edge Windows 10. I can try on Chrome or on my iPad. Too much work to reset everything and put all of the custom names back. Thanks for the help though
Message 5 of 8
Guru
Re: Guest network
Ok, there should be a disable and enable check box. Look for this. Try with a different browser.
Good Luck.
Message 6 of 8
Chuck_M
Mentor
Re: Guest network
Does your GUI look like this?
If not, use Chrome.
My Equipment: Cox Cable (350Mb/35Mb), Orbi AX6000 (RBR850, 3 x RBS850) (2xWired backhaul), NG GS116PP Gigabit Smart Switch, Synology DS1019+ NAS
Message 7 of 8
Guru
Re: Guest network
Any progress on this?
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 940 views
  • 1 kudo
  • 3 in conversation
Announcements
