- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Guest wifi network and main wifi network channels overlap
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I setup a guest wifi network on the Orbi RBK23, but I notice that the wifi channels assigned to the guest network are exactly the same as the ones of my main wifi network (both on 2.4GHz and 5GHz bands). Is this normal? I believe this could cause interferences. Is there any way of manually assigning different frequencies to guest wifi network?
(using Firmware Version V2.3.1.44)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Guest wifi network and main wifi network channels overlap
this is normal. the devices only have one wifi transmitter per band (for the most part). It allows you to setup the guest so it doesn't have full access to your network. It wouldn't have any more interference than 2 devices talking to your regular wifi at the same time.
