Orbi WiFi 7 RBE973
Reply
HELP HELP HELP RBS50 HAND BY HAND CONNECTION
jacky25238787
Follower
1 PC RBK 50 ROUNTER AND 2 PCS ROS50 SATELLITE , IS CANN'T HAND BY HAND CONNECTION.
WHAT TIME UPDATE THIS FUNCTION ?
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: HELP HELP HELP RBS50 HAND BY HAND CONNECTION
Hello Jacky
Can you be more specific on the issue you are having.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1570 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
