Jemckenna
Sep 03, 2019Follower
HP Envy 110 Printer Connects with Incorrect IP Address
I just installed my Orbi and everything works great - except my HP 110 Envy printer connects and is assigned an incorrect IP address.
According to the printer, it is assigned to192.168.2.231.
I’m fairly certain it should be 192.168.1.231.
None of my devices see the the printer now. Is there a fix?
Thanks.
1 Reply
There are a number of possibilities to be explored. Did the Orbi replace an existing WiFi system, or was it added on to an existing system?
What does the Orbi connect to? (brand and model. The concern is if this is a "modem only" - which is preferred, or a "modem/router/wifi" - which is not preferred).
Was the printer here (and working) before the Orbi was installed?
How was the Orbi set up (web interface or "app")?
Thanks
