- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Harmony Hub issues since 2.1.4.16? Coincidence?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi - not sure if it is coincidence or not, but it seems that since I updated to 2.1.4.16 I have been having difficulty using my Harmony Elite. I plan to call Harmony tonight, but I was wondering if anyone else might be experiencing long lags when starting or stopping an activity, the hub dropping off the network, an inability to connect the hub to WiFi during setup? Thanks for any input.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Harmony Hub issues since 2.1.4.16? Coincidence?
Was a full power down of the Orbi system for 1 minute then back on?
Any other wifi neighbors near by? If so, how many?
What channels are you using? Try manual 1, 6 or 11 on 2.4ghz.
Disable MIMO, Daisy Chain and Fast Roaming, save settings and reboot the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks! I did reboot the router, but I guess I could take it and the sats down and restart to see if there is a positive impact.
I guess I wonder why my setting like channels, MIMO, and Fast roaming would suddenly matter (already have Daisy Chain disabled as I don't think I need it). I have had these set as they are with the Harmony working fine until now. Weird.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Anything is possible with these systems and new FW coming out. I know. Just trying to help figure it out.
Could be channels and other users near by with wifi. Could be a change in your surrounding environment as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Agreed. I will try as you suggest and hope for the best...appreciate the input.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know how it goes...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've been having the same problems since updating also.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a factory reset on the Orbi system then setup from scratch as a last resort...
