Orbi WiFi 7 RBE973
Reply
Having an issue with Orbi 2nd satelite
Pmcgarryuk
Hi, so I have a bit of a WiFi not spot. So I had the solution to get a satellite.
I noticed that a complete system was same price as satellite. So I bout the 2nd system as I thought. Brilliant 2 satellites for the price of one.
I have now realised that for some obscene reason this is not the case.
So I thought I would cut my losses and instead use the satellite as an extra satelite. However for all the tea in China I cannot not get the satelite connected. Presumably it is configured for the other network.
How can I connect so that the satelite works with the existing network?
Ps someone mentioned I could run the two networks together with the same SSID,  is that right or more hassle than it is worth?
Thanks
Message 1 of 8
Guru
Re: Having an issue with Orbi 2nd satelite
What is the FW currently loaded on the current Orbi system and satellites?
You sould need to probably update the FW on the newer satellite if it has never been udpated...
@Christian_R
Message 2 of 8
Pmcgarryuk
How can I achieve this if it won't connect in the first place?
Message 3 of 8
Christian_R
NETGEAR Employee Retired
Hello @Pmcgarryuk
Can you confirm how many routers and satellites you have
~Christian
Message 4 of 8
Pmcgarryuk
Originally a router and satellite, then I purchased another router and plug in satellite.
Given I can't use the 2nd router I am hoping to use the plug in satellite. So 1 router and 2 satellites.
Thanks
Paul
Message 5 of 8
Christian_R
@Pmcgarryuk
When you attempt to sync the additional satellite to the original router, what color is the LED ring on the additional satellite?
~Christian
Message 6 of 8
Pmcgarryuk
White pulsing
Message 7 of 8
Christian_R
@Pmcgarryuk
I have sent you a message. Please respond at your earliest convenience.
~Christian
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1451 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
