- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Having issues setting up Orbi on a ATT7T modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have AT&T modem that does not use cable modem so im having a hard time trying to properly configure Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Having issues setting up Orbi on a ATT7T modem
What is this modem? The model number?
Does it have a row of LAN ports on the back? If so there is a chance that it is also a router, which means you can run into problems with having two routers on your network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
