bjornand1's avatar
bjornand1
Help Setting up Two Parallel WiFi Networks
Hi, I hope some of you Orbi experts can offer some advice on this:
I have an Orbi setup with one base station and three satellites. After producing very good WiFi speed in the beginning, the speed is now very poor, and all help I have received points to the number of IoT devices connected, around 50, being the issue.
I am therefore about to set up a second network, using Eero 6, which I intend to reserve primarily for IoT devices. To make the transfer as painless as possible, my plan is to set up the new Eero network with the same network name and ip address as the Orbi network, preserving a number of static ip reservations from the Orbi (and set the Orbi system up from scratch).
Preparing for this, one possibly stupic question is: Can I change the name (SSID) of the current Orbi network ahead of the transfer, without causing any issues with the devices connected (i.e., will they remain connected with the same ip address or will they be "confused" by the change of network name)?
I ask because I named the Orbi network "MySurnameOrbi", but after this transfer, I would like this original network (after it has been transferred to Eero) to be called something like "MySurnameEero" and assign the "MySurnameOrbi" to the new network I will set up with the Orbi system.
Also, any other issues to consider before underaking this transfer, to minimize problems/devices that disconnect?
  • FURRYe38's avatar
    IF you have Orbi system and 3 satellites, this system will be more than capable of handling 50 sevices. Placement and distance is key as well. If your getting bad performance from the system, then some troubleshooting is needed to find out why the Orbi system is operating badly. Adding another wifi system will only make things worse.
    Is the Orbi system operating in Router or AP mode?
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
    For any other non NG branded products, please refer to there help and support web page and community for information regarding there products.
  • CrimpOn's avatar
    CrimpOn
    Numerous Orbi users report having more than 50 devices (some over 100) without impacting performance.  If the majority of these devices are IoT gizmos, their bandwidth usage is minimal.  I disagree with the premise.
    Every time I replace one WiFi router with a new one, I give the new one exactly the same SSID/password as the old so that every device will automatically reconnect.  (and, so that I can "go back" if I do not like the new router).
    The instant the Orbi SSID changes, every device will disconnect.
    This seems inconsistent with the question above. (Can I set up the EERO with the same SSID/password).
    Having two mesh WiFi systems "side by side" is likely to cause interference and reduce the capacity of both.
    If you no longer believe the Orbi is suitable, remove it completely and name the new WiFi system with the same SSID/password as the Orbi.  Or, as I would do, put the Orbi in a closet and reinstall it if the EERO breaks or is disappointing.
    • bjornand1's avatar
      bjornand1
      Thanks to both of you for comprehensive responses!
      I had already ordered the Eero system, which has now arrived, and I have set it up, in parallel with the Orbi system (keeping the IoT devices on the Orbi system and using the Eero system for media and everyday internet usage). As I hoped/expected, it delivers much faster wireless speed, and I don't seem to run into much trouble with interference. The only downside is that for some devices (Apple TV, HomePods) I need to be on the same network as those devices for controls to work fully, so some manual WiFi switching is required.
      I guess there is now way to establish some kind of local connection between the two networks that avoids this (so that devices on respectively 192.168.x.n and 192.168.y.n) can talk to one another directly?
      However, from what you say about Orbi and number of devices, it seems I should be able to make everything work using only the Orbi system. You suggest some tweaking I have not tried (and someone else suggested wiping them and rebuilding from scratch). I guess I will have to try that some day when I have a lot of time, but I deeply fear breaking things that have taken very long to set up, with IoT devices whose static ip-addresses allow Homebridge access, port forwarding to numerous Synology NAS prosesses, etc.).
      • FURRYe38's avatar
        Something you'll have to try for sure. I have my Orbi setup as the main wifi system. 30+ devices with not problems. IoT, cameras, NAS, 3 pritners and two VPNs running all day while at work.
        Good Luck.
