Reply
Help
To connect the orbi system do i have to have to buy a modem , because I’m trying to put wifi in my home but I don’t have a wifi wireless
Model: RBK40| Orbi AC2200 WiFi System
Message 1 of 5
Accepted Solutions
Guru
Re: Help
Yes, the orbi system or any wifi router needs internet services if your wanting internet access. You can use any router with out it for home networking services, however if you don't have internet access, then it's kind of pointless.
My Setup (Cable 1Gbps/50Mbps)>CM1200(LAG Disabled)>RBK853 v3.2.16.22
RBK50 v2.7.2.102
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 5 of 5
All Replies
Guru
Re: Help
How do you get internet? Cable? DSL or Fiber? Wireless ISP?
Most ISP have a form of a modem to access there services and internet place i the home which a router or a PC can connect to.
RBK50 v2.7.2.102
Message 2 of 5
Re: Help
I dont have internet I’m trying to buy orbi system but I don’t understand if i have to have sort of internet cable to conect orbi
Message 3 of 5
Luminary
Re: Help
You need to buy Internet service from a provider and you need a modem of some sort in front of the Orbi router.
Message 4 of 5
Guru
Re: Help
RBK50 v2.7.2.102
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 472 views
  • 1 kudo
  • 3 in conversation
Announcements
