Orbi WiFi 7 RBE973
Reply
Hook up satelite with ethernet
Maradacash
Follower
My satelite is probably out of range, though I do have an ethernet connection back to the router. Can I hookup the satelite via ethernet And sync?
Message 1 of 3
CrimpOn
Guru
Re: Hook up satelite with ethernet
Yes. Probably  a good idea to connect them in the same room with an ethernet patch cable to verify everything OK before moving it to the remote location.
Message 2 of 3
Guru
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
Its recommended to wirelessly connect the RBS first near the RBR. Then wire connect it to ensure the RBS syncs correctly. Then place in it's remote location and connect it to ethernet wire there.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 301 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
