Orbi WiFi 7 RBE973
Reply
Horrible support forn rbr50
thomasmharrigan
Follower
Mac's, multiple ones, multiple smmart phones, ethernet, wifi, etc. My wife started 4 hours ago trying to connect this this router. Should have read the reviews to see how f'd up this product is. The router showed as availbale in the network, she connected, and then it dropped. Been looking through all of the videos, support, resetting, reconnecting, etc. Nothing that cost this amount of money should ever be this hard to work. We flew a monkey in outer space 60 years ago, but can't get an Orbi to connect. I was on hold for 57 minutes, 7th in the que, everything sounded great. Once I finally got to a tech, she was breaking up, as if she wasn't from San Jose, and would drop soon. Within one minute, I lost a connection to the tech. Is this what we expoect from american companies? How do I connect to this piece of crap? My router from 10 years ago, a linksys ea3500 has been a work horse, and never gave me this many problems. I expect Netgear to call me back, doubt it. I should just send this over hyped piece of crap, and lousy support back.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Horrible support forn rbr50
Try contacting a forum moderator.
@Blanca_O
You can try some of the suggestions here while you wait if you want:
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 314 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
