Reply
How To Be Autmatically Notified When Netgear Releases a Firmware Update
Hello,
So I am wondering, is there currently a way to be autmatically informed when Netgear releases a new firmware update for the Orbi Router? Is there a way to sign an email adress up to be automatically notified when Netgear releases a new firmware update or something of the sorts?
Thanks very much.
Model: RBS40| Orbi AC2200 Tri-band WiFi (Add-on Satellite)
Message 1 of 2
Guru
Re: How To Be Autmatically Notified When Netgear Releases a Firmware Update
NG doesn't provide any notifications of FW updates. They do occasionally send out notifications and reminders of security issues and to keep checking your system and support sites for FW updates if you have registered your product with NG. You just have to keep checking here in the forums, NG support site download page for the model you have or check the onboard FW update section of the router.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Router Mode |  Wifi Router CAX800 (Router Mode) and RBK963 (APMode) | and MK63 (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MR6150, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, XR1000, EX7500/EX7700
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 723 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
